Roborock S4 Max
Uncompromisingly Intelligent Robot Vacuuming
Roborock S4 Max brings Roborock’s acclaimed robotic intelligence to a robot dedicated exclusively to vacuuming. Advanced features include automatic recognition of up to 4 maps – ideal for multi-level homes, app controlled Invisible Wall™ and No-Go Zones, and automatic room recognition.Cleanups can also be scheduled in detail based on time of day, room, and more. All without hardware add-ons.
Multi-Level Mapping
Advanced Clean Scheduling
Total App Control
Intelligent Suction Control
Hazard Sensor Array
Multi-Level Memory
Using a PreciSense™ LiDAR system spinning at 300RPM and a suite of advanced algorithms, S4 Max precisely maps an entire level of your home and can recognize up to 4-levels. Put it on the floor you need, press the Clean button, and it will figure out where it is and automatically apply any No-Go Zones and Invisible Wall™ you have in place.
Highly Customizable Cleaning
After its first clean, Automatic Room Recognition will identify each room in your home. Afterwards, you can name each room, and set detailed schedules for specific rooms. Need to clean the kitchen every morning after breakfast, the kid’s rooms after every afternoon art session? Set it with a few taps.
Problem Area Cleaning
When you need to clean a specific area not a whole room, draw Zone around it, set the suction power you want, and send S4 Max on its way. You can create up to 5 zones at once and every zone can be cleaned up to 3 times to really tackle tough dirt.
Detailed Movement Management
Using the Roborock app, drop up to 10 No-Go Zones and 10 Invisible Wall™ on every level without a single hardware add-on. Use this to keep S4 Max away from precious items, troublesome furniture and more. The control is yours.
Breathtaking Suction
Powerful HyperForce™ suction creates up to 2000Pa1 of suction power, pulling dirt and pet hair off wooden floors as easily as it dredges it up out of carpets. Ideal for picking up after messy kids and hairy pets.
Multi-Level Memory
Keeps Carpets Bright
Automatic Carpet Boost automatically ramps suction power to maximum when a carpet is detected, providing a more thorough vacuum. At the same time, the Scratchsafe™ floating main brush lifts up to agitate the fibers of the carpet itself, smashing out trapped dust to leave carpets bright and clean.
Worry-Free Workhorse
The onboard Sensient™ sensor array keeps S4 Max cleaning smoothly even in complicated environments. With cliff sensors look for drops and steps, a vertical bumper to prevent getting trapped under low furniture, a jam sensor on the main brush preventing damage and more, you can leave it working without worry.
Clean Floors, Clean Air
Equipped with an E11 rated3 air filter, S4 Max captures 95% of particles including dander and mold as it travels around your house. This washable filter stays usable for a long time, so you can use it again and again without worry.
Roborock S4 Max
1.
Tested internally by the manufacturer according to IEC 62885-2:2016 / 5.8 standards
2.
Based on internal testing carried out by the manufacturer in Quiet mode on hard floors with a full battery and with no mop system attached. Actual results may vary according to the home environment.
3.
Produced and tested by an independent third party in accordance with EN 1822-1:2009 standards
